camber
camber
JustinTimeToo
camber
JustinTimeToo
How do I make a camber in an object? I googled 'how to make a camber in fusion 360' and I searched this site for 'camber' and nothing comes up.
Do you mean camber as in the slight curvature of a surface? Like the bed of semi-trailer?
N
JustinTimeToo
Yes, a slight inward curvature to the blue surface in the picture above
I see.
There isn't a single function for it.
What you can do is create a new sketch in a side plane through the axis of the knob, and draw an arc that starts perpendicular to the axis and reaches out to the end of the ridges. Then do a revolve cut to subtract it from the main body.
Hope that helps.
Niels
JustinTimeToo
I was afraid you'll say something like this. 🙂
Thanks for the help!
