Cam Set Up unit of measure
The unit of measure in my Model module is set as inches.  However, in the set up screen its in metric/mm.
How do I change these units of measure?
innovatenate
Autodesk Support
Autodesk Support
What are you default units set to in the Preferences for the CAM environment?
For the current design, what do the units say in the Browser?
You can select the Pencli/paper icon to Change the Active Units. Does that help?
Let me know if you have any questions.
Nathan Chandler
Principal Specialist
this is the problem.
http://autode.sk/2dkbZUO
didn't seem to attach a few seconds ago.
innovatenate
Autodesk Support
Autodesk Support
In the CAM environment, the Units are still set to mm. Could this be the issue?
Nathan Chandler
Exactly,  I am sure it has nothing to do with the fact that I can't read, see or do anything the a resembles paying attention to what I am doing.
I am working hard to find a witty excuse. 🙂
Sorry.
Herschell
innovatenate
Autodesk Support
Autodesk Support
That's why you have to love screencast! Get's right to the heart of the matter! I probably should have mentioned that the Units are Environment dependent, noted for next time.
I'm just happy we figured it out!
Cheers,
Nathan Chandler
