bugs!
bugs!
bugs!
I'm encountering lots of weird bugs these days. Today's bug has to do with trying to save save a drawing. It's causing it to hang up, leaving me with nothing but the very pleasant windows "ding" when I click on anything, including the red x close button. The save window appears in the icon stack on the task bar, but only as a ghost, I can't actually click on it to open. It's not popping up on top of the fusion window. So, control+alt+delete I go, only to get the "system cannot end program because it is waiting for a response for you."
Super bummer.
Matt
innovatenate
Autodesk Support
Autodesk Support
From the description of the ding noise, it sounds like Fusion 360 process is hung. Can you walk me through the exact steps you are taking?
For example
1.. Open Fusion
2. Create a New Design
3. Create a Box Primitive
4. Select Save....
and so on..
 If you go to the processes section of the Task Manager (CTRL + ALT + DELETE). You should be able to forcibly end the Fusion 360.exe process.
I hope this helps!
Nathan Chandler
Principal Specialist
mark_stevens
I have this same problem.  I am unsure of what causes it.  I do not know how to exit without killing the process manually.  It does appear to be waiting for user input, but I have not been able to find the input window or enter any input that will cause it to go away.
