Bug with simulation report
cgilbertCEWFQ
Observer Observer
cgilbertCEWFQ
Observer
Observer
After inserting surface probes and checkpoints in a region of my simulation results, along with the min and max values, and selecting the report with all options enabled, these points and the min/max values do not appear in the HTML report (see attached pictures).
This issue did not exist six months or a year ago.
t_kuraa
Hi, you need to save the document for the newly added probes/cutting planes to be available for Report generation. The save is not required if you are using legacy results experience (you can switch back to legacy experience by turning off the preview in preferences). Thanks for reporting this issue I'll forward to the respective team
t_kuraa
HI, good news! the issue has been fixed and the fix will be available in the comming Fusion update
