Bug when mirroring 2-direction extrude-to-object when revolved cut feature pres
Bug found when mirroring 2-direction join extrude-to-object when revolved cut feature present.
Supressing the revolved feature makes the mirroring correct.
http://a360.co/2k7VYbH
Try unsupressing Revolve2, and watch half of the mirrored feature disappear.
(I can work around it, but I think it might be indicative of a serious unintended interdependence in the software.)
David
Phil.E
Great catch. Still investigating.
Workaround: In the mirror dialog, pick Compute Option > Identical or Optimized. The "adjust" option is doing too much adjusting. 🙂
Edit:
Another "workaround" would be to mirror the two faces rather than the feature. There are a few other ways to model this.
Thanks for catching this and making the post, it's logged.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
