Bug in Sketch Rectangular Patterns: Distance Type changes unexpectedly when edit
robduarte
robduarte
After creating a rectangular pattern in a sketch, I edit the pattern and the Distance Type has switched from Spacing to Extents which screws up the pattern.
Please see this video for a demonstration: https://youtu.be/jsgbcoKX5IA
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
innovatenate
Autodesk Support
Autodesk Support
Thanks for sharing this. I can reproduce the distance type (spacing/extent) reverting upon edit and the inability to select the same sketch entity to be patterned as a direction reference.
The latter case, I'm not sure if it is working as designed or not, but have logged it anyway under report ID, FUS-23688.
The distance type issue seems like bug and I have logged that under report ID, FUS-23687.
If you have any questions, please let us know. Thank you again for reporting this!
Nathan Chandler
Principal Specialist
billbucket
I'm having the same issue while making a pattern of features along a path. The preview for the spacing shows up fine when the settings window is open, but it switches to extent distance type once the window is closed. Opening the window again it still shows, and previews, the distance type as spacing.
Workaround appears to be deleting and recreating the pattern, though this only worked for me on the third attempt.
