Bug? fusion 360 sketch offset forces lines to same normal/construction state
matt
matt
To reproduce:
  • create a sketch
  • draw a line
  • use sketch offset tool to create an offset copy of the line
  • select the new line and convert to a construction line.
  • change the value of the dimension created during the offset operation
behavior: New line reverts to a normal non-construction line
expected: construction state of a line should be independent of the offset operation
version 2.0.2139
I'm trying to project existing geometry into my sketch, convert to construction lines, then create normal lines slightly offset for clearance. This seems like a reasonable workflow.. am I missing an easier way?
kris_berg
Hi @matt,
I agree that behavior is not desired, however I would need to defer judgement to the UX (User Experience) Designer for that feature and they are on vacation this week.  Searching our defect tracking system I ran across the following item "FUS-17085 - Offset should inherit the attribute of its source" which is the way it is behaving now.  I apologize for the delay, but I will ask them to reply to this thread when they return.
Thank you,
Kris Berg
Senior Software Architect - Autodesk
matt
Thanks for your help.
re:
>...Offset should inherit the attribute of its source
I agree that this should be the behavior when the offset is first created, but surely not after it is deliberately changed.
I look forward to your updates.
-Matt
FrankCao
Hi Matt,
Thanks for reporting this issue. The problem you found is a bug we have also found during internal testing and several other forum users are complaining about this either. Our developer is currently working on a fix for this issue. And hopefully it will be addressed soon.
Frank
Glad to hear that this bug is being worked on.  I too have experienced it often.
matt
I just discovered that this seems to be fixed in 2.0.2449
Thanks Autodesk.
-Matt
