[Bug] Edit Profile Sketch goes to edit feature command instead
XanderLuciano
Message 1 of 13
XanderLuciano
Hey guys,
Got another quick bug for you guys. If you right click a feature and choose "Edit Profile Sketch", it will take you to the "Edit Feature" dialog, and not into the sketch. Here's a screencast of the issue.
Replies (12)
Message 2 of 13
jeff_strater
Good catch, @XanderLuciano!  To be perfectly honest, I had completely forgotten that this workflow existed, where you can select a face and choose "Edit Profile Sketch", and then if more than one feature contributed to that face, you are given a choice of which feature to edit.  I always tend to select features in the timeline.
Anyway, you are correct, this is a bug.  I'll report it, and get it on the list of things to be addressed.
thanks for reporting this.
Jeff
Jeff Strater
Engineering Director
Message 3 of 13
XanderLuciano
Thanks once again @jeff_strater!
I prefer clicking on the feature because once you start getting to longer timelines I find I'll spend a good amount of time clicking on different extrudes trying to figure out which extrude is the one I wish to edit.
Thanks!
Xander Luciano
Message 4 of 13
TrippyLighting
Thanks!
Xander Luciano
This only the case when you are not following Fusion 360's R.U.L.E.#1: Before doing anything, create a component and make sure it's activated.
  1. All objects created after activation such as sketches, bodies, construction geometry, joint origins are created in that component.
  2. If you want to edit another component to add geometry, activate it before doing so. It will filter the timeline only for those items in the timeline that pertain to that component. As the timeline grows in a design this will make dealing with it a whole lot easier.
  3. Another reason for that workflow is that if a component is to be used in another design and needs to be exported (save as) to live in its own file inhale data panel, this will ensure that the compete parametric design history is exported with it. If you use a workflow that first creates sketches and then bodies and then turns the bodies into components you'll  find out that your exported component only contains a "dumb" body but all the design history is lost.
Fusion 360 R.U.L.E #2 is : Name your stuff.
Fusion 360 allows you t name about everything. You can also name items in the timeline and group items in the timeline and then name the group. Once I notice that I am hunting for items in the design I'll start naming at least the ones that I find myself going to.
Also good catch on that bug!
Message 5 of 13
XanderLuciano
Thanks for the tips! I come from solidworks so I'm used to a certain workflow. The Rule #1 still doesn't quite work for components that have many extrusions on them. Often time when I'm in fusion I'm just trying to quickly prototype a part and I don't want to go through naming everything until I solidify the design. I'll name bodies and components, though I don't see a way a to name extrusions like I can in solidworks, unless I'm missing something?
Thanks for the tips! 🙂 If you can, maybe post a link to the page where those rules are so others can review them.
Message 6 of 13
TrippyLighting
Extrusions are features accessible through the timeline.
You can also name items in the timeline.
Message 7 of 13
jaknil
Hi Jeff!
This bug is still there. Did it get a tracking number so that I can vote for it somewhere?
I would really appreciate if it got fixed.
Best Regards Jakob
Message 8 of 13
xander.luciano
@jaknil
Looks like this was logged as FUS-25957 but I'm not sure what the current status is. @jeff_strater Would you happen to have any additional information on this bug?
Best,
- Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Message 9 of 13
jeff_strater
This bug is still open.  No idea when it might get addressed, sorry.
Jeff
Jeff Strater
Message 10 of 13
jaknil
Hi Jeff!
Two year anniversary of this bug being first reported coming up soon, any chance it will be addressed? 🙂
Not a programmer but I would hope this is just a pointing/linking error that could easily be fixed?
I find the "Edit Profile Sketch"-feature is great for hunting down the right sketch to edit, especially when dealing with super long timelines.
Best Regards!
Message 11 of 13
bkeyesAVRWC
Observer
Observer
Happy 4 year anniversary of this bug! Any updates?
Message 12 of 13
sharkyus379
Observer
Observer
2022. The bug hasn't been fixed yet.
Message 13 of 13
TrippyLighting
Can you provide an exmple?
