Bridge error in Form mode
travis.designer.vn
Message 1 of 8
travis.designer.vn
Hi
I try to use Bridge in Form mode. They say error when I finish. Please view attached video for more details.
Best regards
Travis
Replies (7)
Message 2 of 8
Johnc911
Message 3 of 8
travis.designer.vn
Hi John
Can you give me more detail? Will we use Merge Edge feature?
Message 4 of 8
TrippyLighting
Please use the free Autodesk Screencast utility.
Message 5 of 8
travis.designer.vn
Hi Peter
I try Autodesk Screencast but It's uncomfortable with me (always require to upload).
Do you have any suggestion for my case of bridge error?
Message 6 of 8
TrippyLighting
I cannot view your video and will not view mp3 attachments. That format is inconvenient for me and most other users ho help her on the forum regularly. If you want help, then please use the suggested tool, because it is convenient for us 😉
IN general, there is no bridge error. You can't merge edges, because the bride you created has a number of faces, which do not match the number of faces of the box you created.
Message 7 of 8
travis.designer.vn
Hi Peter,
I did it. However we need a lot of steps to do simple job. At the first idea I just want to cap.
Message 8 of 8
TrippyLighting
Well, not really. If all you need is a dimensioned box with 1 subdivision that is much easier to do and no sketch is needed. So instead of complaining, maybe spend some time familiarizing yourself with all the tools in Fusion 360 😉
