Break Reference
Break Reference
machfab
Message 1 of 12
Break Reference
machfab
If there are copies of components in an assembly, is there any way to break the reference between them?
So you can modify them on an individual basis. (modify one and not affect the other)
Replies (11)
Message 2 of 12
TrippyLighting
You can either make an instance of a component when copying it with "paste", or an independantly editable copy with "paste new"
However, that requires you to know upfront wheter you want to edit that copy independently. If you first create an instance and then later decide that you want to edit it indendently I dont think that can be done at the moment.
This would be a good suggestion for the idea bord! It may have been sugpested already and if so vote for it. If not then add a new suggesion.
Message 3 of 12
Oceanconcepts
Yes, right click on the component in the browser and select "Make Independent".
- Ron
Mostly Mac- currently M1 MacBook Pro
Message 4 of 12
San_Escobar
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
Message 5 of 12
San_Escobar
Hey machfab
Sure! For instance yesterday I accidently delete one part which was used for assembly. I thought I was deleting one the update but unfortunately I deleted the whole lot. ANYWAY.
Then, when I open the Assembly in Fusion and  unlike any other CAD software, I thought that my assembly would fall apart but it didn’t.
So, I just carefully deleted all the pieces that I didn’t want, to clean the file as max. as possible so them I saved as: and gave a different name and location. Now de results are bellow: Check the Timeline and Feature Tree/Browser.
Now whenever I change something on part model it doesn't affect the assembly.
HTH, Happy modelling.
Message 6 of 12
TrippyLighting
I must be sitting on my eyes 😕
My assembly is  full of instances but I dont see that option in the menu (?)
Message 7 of 12
Oceanconcepts
I see this option if I have a copied instance of a component.
- Ron
Message 8 of 12
TrippyLighting
I dont 😞
Are you on a Mac and what version are you running (2.0.1462 here) ?
Message 9 of 12
Oceanconcepts
I'm on a Mac, but  I'm in Direct Modeling at the moment. I think the issue is that this option is not available if you are in History mode.  Possibly the intent is that if you are in History you could just roll back the marker and re-do the copy- paste.
- Ron
Message 10 of 12
TrippyLighting
Excellent observation. That did not come to my mind! I do almost everything in Timeline mode.
Message 11 of 12
machfab
So....
If you are in History mode and the components were created using "Pattern" (not copy/paste), the component cannot be made independant?
Message 12 of 12
TrippyLighting
I'ts eaasy enough to try but I don't think you can do this in history/timeline more at all. Patterned or not.
