Hey Guys,
I'm very new to 3D modeling and I've been struggling trying to get a boundary fill cut operation to work. I can't seem solve the issue.
I need to cut a recess in a fuselage to set a fan shroud into (see screencast below). I was able to use boundary fill to successfully perform the same operation using different bodies (the inlet and outlet that connect to the fan shroud). You can see those recesses have already been cut in my screencast. I keep getting errors on this particular part that I haven't a clue how to resolve:
Reference Failure - Some sculpt cells are mismatched.
I even tried re-creating the fan shroud, but still get the same error on the newly created body. Any help would be greatly appreciated.
Taylor
