body dimension display
derricksalmon
Message 1 of 24
derricksalmon
I'm a newbe.  I have a rectangular body in a previous project I have just re-opened.  I would like to see the dimensions on the monitor but cannot fi
Replies (23)
Message 2 of 24
LMD001
Hello derricksalmon,
Welcome to the community!
To measure a face you can select the face and use Inspect-Measure.
A similar post about this: http://forums.autodesk.com/t5/design-validate-document/measure-part-perimerter/td-p/6208387
Hope this helps.
Best regards,
Ludo
Message 3 of 24
LMD001
Hi derricksalmon,
If you want to see the dimensions of the underlying sketch you can use RMB on the sketch and activate Show Dimensions, also activate the lightbulb on the left of the sketch:
Best regards,
Ludo
Message 4 of 24
JBerns
Ludo,
Why is the light bulb yellow next to the option to Show Dimension. Shouldn't it be blue indicating that it is currently off or hidden?
This is not consistent with the light bulb indicator next to sketches, bodies, components, etc., which indicate whether they are shown or hidden.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 5 of 24
TrippyLighting
@Anonymous wrote:
Ludo,
Jerry
Excellent point!
Please add this to the Idea Station, you'll have my vote!
Message 6 of 24
Cowski
This is good info, but how do you show the body dimensions as you would in a sketch?  Is there a hotkey?
Thanks!
Message 7 of 24
@Cowski if you mean something like this, then to my knowledge that's not implemented in Fusion yet.
Message 8 of 24
Cowski
Yeah, that's what I was talking about.
Huh...weird you can get dimensions on a sketch but not a body.  Would be very helpful.
Thanks for replying and bringing me up to speed.
Message 9 of 24
colinwroberts
Yah, that would be awesome! You think they would have added it as measuring is a key component! HA! 😛
Message 10 of 24
Beyondforce
@Anonymous,
Please if add this to the Idea Station, I'll vote for it!
Cheers.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 11 of 24
Hi There,
Does anyone know if this was implemented?
@Anonymous what software did you use to add those dimensions you showed?
Thank you in advance!
Message 12 of 24
Cowski
I haven't found that this has been implemented yet but I'm getting along actually quite well without it simply by hitting "i"  and measuring the 2 points I want to get the dimensions on.  Not the best solution, but until they implement it into the software, it will work for me.
Message 13 of 24
Has this been added to Fusion yet?
Message 14 of 24
Nevermind, I just figured out that this can be done by creating a new drawing and then dimensioning it out 🙂
Message 15 of 24
how 😕
Message 16 of 24
andresGPZMB
I think he means:
creating a sketch
projecting the points from the body onto it
adding dimensions to the points
then finishing the sketch
right-clicking on the sketch
selecting "show dimensions"
Message 17 of 24
I believe he is accomplishing this using the "New Drawing from Design" function.
Right click on file
Select New Drawing from Design
Insert the part with your preferred view applied
Use the dimensioning tools from the ribbon to apply your measurements to the drawing. (it is not automatic but better than using the Measure function within fusion as the file retains your applied dimensions.)
Message 18 of 24
TheCADWhisperer
@Anonymous
Who is “he”?
Are you referring to the SolidWorks image posted by @Anonymous ?
How would you reproduce that functionality in Fusion?
Message 19 of 24
He in my post refers to DSiddens.  In the thread, dsiddens states "Nevermind, I just figured out that this can be done by creating a new drawing and then dimensioning it out" but does not state how to get to the functionality.  andresGPZMB states that he believes dsiddens was dimensioning a sketch by projecting the body onto it.
My post provides the instruction for launching the "New Drawing from Design"
Right click on file
Hope this helps...
Message 20 of 24
andytpks
Hi, good news?
I think direct 3D dimensions are a good idea and simple to implement, thank you!
