Message 1 of 8
I am building a weldment with a lot of different bits and pieces welded on. Many of these pieces are attachment points for other accessories, and they will be attached to this weldment after it is imported into an assembly as a linked component.
I would like to build these different bits and pieces each as a separate project, then import a linked dumb solid made up of combined bodies from that project, and combine all of these bodies in the final weldment. In the end, the weldment should be one single body.
For this project, I don't want to work with components and joints. Is it possible to do this with just bodies?
