Bicycle Model Breaks When Changing Dimensions
dustindriver
Message 1 of 14
dustindriver
I've been working on a model of a cargo bike: https://a360.co/3SnIIgK
I have a base sketch that includes the base geometry of the bike. I can update the base geometry in the base sketch and most of the model will update. For instance, I can increase the length of the down tube and adjust the position of the central steerer tube and the frame model will update no problem. But the forks component will break.
I think I've done something wrong when I set up the forks. I drew them on a plane at an angle along the fork centerline. When I make changes to the base sketch, that plane remains stationary and the fork model breaks.
Any way to fix this, or will I just have to re-draw the forks?
Thanks!
Replies (13)
Message 2 of 14
TheCADWhisperer
@dustindriver
Can you File>Export your *.f3d or *.f3z file to your local drive and then Attach it here to a Reply?
Message 3 of 14
TheCADWhisperer
You will have to create a new plane as a function of the base sketch and then redefine the fork sketch to that new plane.
This should be easy (if everything else was done correctly (unfortunately this is unlikely)).
Message 4 of 14
dustindriver
Thank you, I'll give this a try! Hopefully it's set up correctly, I followed the methods outlined in this bike frame tutorial: https://youtu.be/XemlmN-CWmM?si=FRe_T-o0gdc2emt0
But yes, I am unfortunately not formally trained. Yet.
Message 5 of 14
dustindriver
Here's the file, thanks! I truly appreciate your help. I'm having a blast learning Fusion 360, it's been a lot of fun.
Message 6 of 14
TheCADWhisperer
Is the file that you Attached in condition BEFORE the model breaks as described or is it in the BROKEN condition?
Does Ctrl b (CMD b on Mac) return any unresolved issues highlighted in the Timeline?
Message 7 of 14
dustindriver
That is the model before it breaks. Here is the broken model. Thanks!
Message 8 of 14
dustindriver
I have a lot of errors, I think I should start a new file with a new base sketch and build it out from there. NBD, I have the base measurements so it'll just take some time to build the file correctly.
Message 9 of 14
TrippyLighting
I ran a CTRL-B (Modify->Compute all) on the file that you sate is not broken.
When modifying a sketch, particularly when deleting and adding new sketch objects to a sketch earlier in the timeline, run a Compute all. That is your basic quality management of the model. If that returns no warnings or errors, then you can proceed.
Otherwise STOP, undo determine the root cause and fix it before continuing with modeling.
Also, routinely during modeling, check that your parameter changes actually work. Don't wait until the model is done! That makes it much easier to find and fix problems.
Message 10 of 14
dustindriver
Thanks for your help! I rebuilt the model, being very careful to label everything and create separate components for all the frame parts. Also made sure to project the base sketch geometry into all the parts. No errors now and the model updates as expected when I change the base sketch. Thanks for your help and for reviewing the file, I really appreciate it!
Message 11 of 14
TheCADWhisperer
@dustindriver
You still have several sketches that are not fully defined.
I would even fully define the Construction lines.
Message 12 of 14
dustindriver
Ah, good catches! I used the Sketch.ShowUnderconstrained command to find the unconstrained points. Fixed them all. Still, the construction lines on the base sketch feel messy. Suggestions?
Message 13 of 14
TheCADWhisperer
@dustindriver
I tried to post a more detailed answer, but for some reason the forum gave me an HTML error.
I will try again.
I would never use a meaningless 8 decimal place dimension in a sketch.
Instead add a logical Coincident Constraint...
Endpoint should turn from white to black after applying the appropriate constraints.
Message 14 of 14
dustindriver
Thank you! That's embarrassing and I cleaned it up. Thanks again for all your help!
