Better version support inside Fusion360
BrienKing
BrienKing
Unless I've missed it somehwere, I don't see any support for dealing with versions within Fusion360 at all.  You have to go to the web site to deal with versions.
What I would like to see is this:
1) Version window that shows a list of all the versions for the open design along with when it was saved, etc....
2) The ability to view and compare versions (the compare could just be a new window open with that design so I can look at them side by side).
3) The ability to roll back to a particular version.
4) Create a new Design based on a specific version.
I know you can do a lot of that from the web page, but it would be a lot more productive and intuitive to be able to do that from within Fusion360.
Brien King
spammehere@arcaderestoration.com
http://www.arcaderestoration.com
schneik-adsk
You can actually do those actions in the data panel in Fusion today.
When looking at a design in the data panel there is a text link to show versions.
When you expand this there are two buttons that appear as you hover each version. These allow you to promote an old version, open an old version (read only) to compare and you can save as an old version to create a new item if you need to, I hope this helps!
Kevin Schneider
schneik-adsk
Kevin Schneider
BrienKing
Excellent!  Thanks!
Brien King
