Better Dogbone Fillets
Helmi74
Helmi74
has anyone yet found better solutions to create Dogbone fillets for milling than using this Addin: https://github.com/caseycrogers/Dogbone?
I still think there should be some integration in CAM for this as you might want to change tools and therefore not "hardcode" the tool size into the design. Also the script fails relatively often on pieces with a few more inner cuts.
Currently working on some bigger screw trays and sorting boxes for my shop and i think i may have to use some other software for milling as the dogbone fillets keep driving me crazy.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
daniel_lyall
this one works a bit better but is still just as limited https://github.com/tapnair/Dogbone
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Helmi74
the one you linked seems to be a month older - at least the python file. Are you sure this one works better?
Frank / @helmi
daniel_lyall
last time I looked they where still diffrent casey's one had only a single selection directly in the corrner, the tapnair one had two mode's of selection, casey may have made them the same
Daniel Lyall
The Big Boss
Mach3 User
Jon.Dean
Hi Frank,
I suggest you request an enhancement on the Fusion 360 IdeaStation.
I would also add the link to this forum post for additional information.
Jon.
Jon Dean
Helmi74
I finally found the time to add an idea station post.
Here it is - like to get some votes on it 🙂
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125/tab/most-recent
Frank / @helmi
daniel_lyall
done
Daniel Lyall
The Big Boss
Mach3 User
