11:35 AM
I have a quick question to the experienced folks out here. I have a design model with 4 components and one of them is a lid where I have two different designs in mind and like to decide on the final one once I have seen them both after a prototype 3D print.
1. Is it good practice to put the second design of the lid in the same file and switch on/off the one that you like to see? Or would you put the alternative design in a second file ?
2. Am I correctly assuming that copying a component is as easy as it sounds?
Thank you for your input?
Cheers
