Bending a 4x8 sheet of plywood to a specific radius
jefftaylor2010
jefftaylor2010
Looking for tips on how to bend a flat 4x8 sheet of plywood to a radius (84" radius),plywood is 3/8" thickness.
The short side of the sheet would bend along the 84" radius
Drawing a mini-ramp as a self tutorial and am stuck at this step... Thanks for any tips!!
TheCADWhisperer
Why not model in finished form?
Knowing the circumference of a circle radius 84, you can calculate the angle for 48 inch arc length.
(See Attached)
jefftaylor2010
Trying to figure determine exactly where a full 4x8 sheet ends, so I can add an extra 2x4 below the edge of the sheet, to have something to screw the sheet to.
TheCADWhisperer
File>Export and then Attach *.f3d file here if you can't figure it out.
jefftaylor2010
See if this works...
Thank you for your help!
TheCADWhisperer
