Beginner Question - Enclosed warped sketch won't be able to be selected as a face to extrude from
alexmougenot
alexmougenot
Hey everyone!
I am designing a rock climbing wall with an angled wall. This angle is slightly warped.
I have created the sketch from which I wanted to extrude the front face to the width of the plywood sheet, though the face isn't able to be selected even though it is a closed sketch. I suspect this is due to the warped nature of the wall? Any help is greatly appreciated!
I have attached pictures and the .dwg file for reference.
Alex
Screen Shot 2021-04-14 at 1.36.18 pm.pngScreen Shot 2021-04-14 at 1.36.02 pm.pngScreen Shot 2021-04-14 at 1.35.46 pm.png
davebYYPCU
Surface > Loft
1 to 2, and then Thicken
Might help....
dsouzasujay
Hi @alexmougenot ,
I followed the same as @davebYYPCU mentioned.
But, Extracted surface by using offset surface from solid bodies and new surface from the sketch reference.
Finally Stitched.
You can make them solid again by adding "Thicken"
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
alexmougenot
Fantastic - thanks so much you two! Also, I have now made a grid of holes. I really appreciate the help
alexmougenot
Woops I didn't elaborate my reply. I now want to place a grid of holes onto this surface. I have managed to learn how to use rectangular patterns to make hole grids on the other plat solid panels, though I'm struggling to do the same on this curved surface? Any ideas?
dsouzasujay
@alexmougenot ,
For curved surface we need to use 'Circular Pattern'.
I can understand clearly only if you share an image or dataset.
You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
