Basic sweep cut on discreet sketch lines
jeusterbrock
jeusterbrock
I'm trying to engrave a surface with a streetmap. I'm running into trouble with the 'pipe' or 'sweep' function because it only allows me to cut one section of line at a time. It would be a huge hassle to manually 'pipe' 40-50 discreet lines and the selection tool won't let me select more than one line at a time.
I've included a photo sample of what I'm talking about.Screen Shot 2017-03-02 at 11.49.09 AM.png
There must be a simpler/more efficient way to make these cuts. does anyone know?
Thanks!
jeevesme
I'm not sure if you need a pipe shape, but if not, you can go into the patch environment, select all of your sketch lines, extruded them, then thicken-cut them.
_________________________________________________________________________________________________________________________________________Forever yours,
Love,
Brian
PS. If this answered your question, please mark as answered so others do not read through the posts trying to figure out if it was answered.
jeusterbrock
Hi Jeevesme,
Thanks so much for responding to my question. I like what you did with the patch extrude tool. While that gets close to what I'm looking to do, its not exactly what I was asking.
The pipe shape is actually important because I'd like it to mimic the cutting tool (a ball end mill).
Do you know any other workarounds to cut a semi-circle profile along an array of discreet sketch lines?
It seems like the 'pipe' or 'sweep' function would be most well-fit for the function, but perhaps theres another tool I don't know about.
Thanks!
davebYYPCU
Combine cut the piped street map in one go, this vid was for split body, not exactly what you want, but gives you a "how" to join the sweeps together
At 2.15 on this video you will see a technique to compile the street map into one body, by joining all the articles outside the target body, then it is one selection,
https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/04e43...
Not seen your model, adapt patterns if you can for the sweeps, then join to one grid, then subtract the grid from the surface,
Sort of how I would approach it...
