I had some basic questions while working with control point splines:
1) Continuing a spline: Is there a way to continue drawing an existing spline without creating a new spline? So if I exit a spline drawing mode and want to go back to drawing the same spline later on. Right now when I create a new spline it doesn't maintain continuity with the previous spline and fusion essentially treats them as two splines which results in two faces if I extrude these splines.
2) Closing a spline: Is there a way to close the cv spline so that it doesn't end in a kink when closing the curve ? Currently I have to manually add parallel constraints on the control frames to get smooth end.
If anyone is familiar with Rhino, you will know that continuecurve is the command that solves the first problem. And sharp/close option in the curve command addresses the second problem. Wondering how to address this with fusion with a little less pain.
Thanks!
Numan
