Basic multi-line dimensions with tolerances
The figure shown is an example of fundamental hole dimensions showing two lines of text and including tolerances. The tolerance (.7600-.7600) is not the feature that was selected for the dimension feature. That was, properly, the 1.06 diameter hole. However, I cannot figure out how to get Fusion to
a) create two or more lines of dimension text, and
b) create tolerances (stacked limit dimensions) in the dimension text (not the selected feature - that's easy).
Can Fusion make these dimensions as shown? If so, how? And if not, WHY NOT!!!???
Link copied
