Bad dimension from svg
paysagine
paysagine
I draw a square 100*100 mm in inkscape. export svg and import in fusion.
the dimension in fusion as bad.
I don't understand with a dxf and the same 100*100 mm square import from librecad in fusion
Dimension is good.
Can you Help me ?
I don't understand
thanks a lot
laughingcreek
hard to know for sure with no file or visuals.
but
inkscape isn't cad software.  I wouldn't expect it to outtput geometry that is perfect.
also, you will find all through these forums posts where the issues being encountered could be traced directly back to imported svg curves.  svg curves should never be used to produce solid geometry.  it's just asking for trouble.  works sometimes, frequently goes horribly wrong with now obvious reasons.  the quality of imported svg curves is generally pretty terrible.  The general suggestions is to always redraw imported curves with native fusion curves
obious
I've just gone through this exact problem. My solution was to change the scaling to 1.3333 during insertion and my import was rendered at the correct size
LeonardoBN
I have the same issue with SVG files. I create SVG files in CorelDRAW of some intrincate text fonts Fusion does not handle well.
As my text size does not need to be exact, I adjust the imported SVG by hand.
Leonardo Brunelli do Nascimento
Chemical Engineer
paysagine
Hi Thanks for your help.
For me the ratio is 3.77953232
I work with mm and the size is correct
