AV in drawing while adding chained dimension
etfrench
Mentor Mentor
etfrench
Adding a chained dimension resulted in an Access Violation: CER_120177654
Prior to the AV, I was experimenting with dimensions to see how to get the best placement. Dimensions were created and deleted on the same object several times.
Fusion 360 Drawings Error Aborting
FATAL ERROR:  Unhandled Access Violation Reading 0x00d8 Exception at bbe05056h
Ok
Clicking on 'OK' opens the following dialog:
Fusion 360 Drawings Alert
Fusion 360 Drawings cannot continue.  You can attempt to save changes
into the following file up to the start of the last command:
Drawing1_recover.dwg
After you save your changes, you can open or recover the file.
Should Fusion 360 Drawings try to save your changes?
Yes   No
Clicking 'Yes' opens the following:
Fusion 360 Drawings Error-abort
Error handler re-entered.  Exiting now.
Ok
End result is a blank drawing with Fusion 360 still running.
ETFrench
cmiller66
Hi etfrench,
Thank you for reporting this and for sending in the Customer Error Report (CER).  Are you able to reproduce this or was it a one time crash.  I checked your CER and so far yours is the first/only one in this bucket.  So it sounds like you placed dimensions, deleted them, re-created them, etc then going to chain dim caused a crash.  I'll try to repro this in house.  At any point did you UNDO?
Chris
etfrench
It hasn't repro'ed on a new drawing with the same assembly.  I usually used the Undo function to delete the dimensions, but may have also selected and deleted from the context menu.
ETFrench
cmiller66
Hi etfrench,
OK, thanks for letting me know.  I'll give it a shot (so far no repro for me either).  If you do hit this again please let me know and please continue to send in any/all CERs you may hit, they definitely help us identify where the problems are and get them fixed.
Chris
