Sorry to cross pollinate CAD systems here, but I am really looking for a way to emulate the Pro/E functionality of a reference pattern. Meaning you create a pattern of holes, assemble and joint a component (pin, screw, whatever), then pattern the component and Pro/E automatically populates the entire pattern of components based on the hole pattern that the first component is referenced to (hence a Reference Pattern).
Is there such a feature in Fusion 360? Using one pattern to automatically drive another pattern? Or just automatically populating all the holes in a pattern with components? What about defining the first hole, then adding the component and jointing it to the hole, then create the pattern and select the hole AND the component as the items to pattern? (I actually tried this one, Fusion 360 will not allow one to mix pattern types (feature vs. component)).
