Automatic upload
Automatic upload
Automatic upload
Is there any way to stop files being uploaded automatically?
masa.minohara
Hi @Anonymous,
Thank you for posting! When you said "automatic upload", did you mean uploading design files when you save them? If so, you can use "Export" option in the File menu to save files in the local drive. Also, when opening local files, you can use "New Design Form File" option. I hope this information helps! Please let me know if you have any questions.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi Masanobu,
I have been using the offline mode and it is a great function but what I was speaking about seems to be a misunderstanding on my behalf.
I found a number of practise renders uploaded which I then had to delete, I am not sure if it was a bug in the last build but when I tried to delete the render images in the program they would not disappear and then they were uploaded automatically on the next save.
The program updated itself yesterday and I have just tried to delete the images and they have disappeared and have not been uploaded this time.
I do have a request concerning the save function; please let me know if I should post it on another board?
When we save the file, the program responds with a box that says User Saved, it would be great if that box could contain the files original name because most users would want to overwrite the file they are working on.
If the user wanted to rename the file they could change the name but I think most users would prefer to overwrite the file they are working on when they save?
masa.minohara
Hi @Anonymous,
I'm sorry for my slow response. So has the issue been solved since the Oct 5th update?
Regarding the box with "User saved", did you mean the box below?
If you meant this one, this is not for a file name but for version description, and a file gets overwritten automatically when you save. You can check the version descriptions in A360 page.
Also, if you want to rename a file, you can use "Save As" option in the File menu.
Masanobu Minohara
Hi Masanobu,
I am happy to say that all my issues on this disappeared with the last update, everything is working as it should now.
Thanks for your help on this.
Craig
