AutoDesk Fusion 360 error during installation
Attempting to install Autodesk Fusion 3 and get this error message
. Please attach the file "/Users/mmitsuda/Library/Logs/autodesk.webdeploy.streamer.log to any problem reports before closing this dialog
innovatenate
Autodesk Support
Autodesk Support
I'm seeing a Errno 11003 reported in the log files.
Are you installing from within a proxy environment or a secure office network?
The suggestions in the below link may be helpful in resolving the issue.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Netw...
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Inst...
I hope these suggestions help. Please let us know if you have any questions or concerns.
Thank You!
Nathan Chandler
Principal Specialist
steven.yang
Could you help us doing a test? We cannot reproduce this failure.
Please open the “Terminal”.  Terminal.png  ( It can been found by using “Spotlight”)
Then paste the command and hit “return” key. It will output the information on the Terminal.  Please copy the information and report it here.
The command is:
openssl s_client -connect dl.appstreaming.autodesk.com:443
brad_hurley
Autodesk Support
Autodesk Support
@Anonymousmmitsuda
To resolve any issues with the firewall, try the following suggestion
  1. Choose > Apple menu > System Preferences, then click Security & Privacy
  1. Click on the lock icon to unlock it, then type an administrator name and password
  1. Choose Firewall and click Firewall Options
  1. Drag the following .app files from a Finder Window to the List of applications in the Firewall Options
For Autodesk Fusion 360 version:
~/Library/Application Support/Autodesk/webdeploy/production/<Application ID***>/
***Note the Application ID will change with each version of Fusion 360
Autodesk Fusion 360.app
Fusion360Connection.app
NLauncher.app
NLauncherConfigurer.app
For Mac Apple Store Fusion 360 version:
NLauncher.app
~/Applications
Fusion 360.app
  1. All app files should have “Allow incoming connection” next to them
  1. Select OK and then Lock the settings
  1. Re-Test Fusion 360 and see if the behavior has changed.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
BHurley
Autodesk, Inc.
