Autodesk Assistant Render
admaiora
Mentor Mentor
admaiora
After seeing this,
https://www.youtube.com/watch?v=imfLK1yN4Ls
I tried, but Autodesk Assistant replies this
—any ideas?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Austin_V_Autodesk
Hey there. 3 main things to check:
  1. you have an active Fusion subscription
  2. you're on the latest client version (Check for Updates)
  3. you have opted into "Tech Preview" in Autodesk Assistant - the badge in the AA window should be purple when this is properly enabled
Let me know if you are still unable to get image generation working after confirming those!
Best,
Austin
Austin Vojta
Product Manager, Fusion, Consumer Products
admaiora
Hi!
  • you have an active Fusion subscription
ATC licenses
  • you're on the latest client version (Check for Updates)
yes
  • you have opted into "Tech Preview" in Autodesk Assistant - the badge in the AA window should be purple when this is properly enabled
yes
Admaiora
admaiora
We managed to get it working, but we had to log out and log back in.
Admaiora
