@Phil.E @balunist
hi Phill,
sketchip is a pretty low level polygon modeler and like other polygon modeler you can texture faces and complete objects via materials that can include solid color or texture values.
translated to fusion in sketchup materials are what in fusion we define through the appearance dialog.
we are not using real physical material descriptions like steel plastic etc in sketchup.
Sketchup is sadly very popular because it is quite easy to learn but what most people don’t rlealize is how crippled and limited that app is.
It is used a lot in architecture and 9nterior Design while you can also use it for furniture design and other areas.
what makes sketchup so popular in architecture is that fact that there is a large online library of models and even companies offer their prosucts
as 3d models to put into an architecture space or such.
i have my students a test run in fusion and they are caughing at sketchup now since they realized how much better fusion is for modeling of objects to walls and spaces
since fusion is also significantly more logical and more productive than AutoCad which offers 3d capabilities but in such an outdated manner that it makes it a bad choice
hence the push to revit.
the fact however remains that sketchup remains being used s lot because how cheap it is and fortunately fusion can make desings we can export to sketchup or even revit later.
the only thing missing for the sketchup export is the ability to define the mesh quality. Often sketchup exports from fusion are pretty crude.
and maybe fusion components could be exported as sketchup components since they both work the same in each app.
i hope this helps a little to get an understanding of how we use fusion and sketchup together
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
