Attributes on drawing, but not within Title Block.
Leo_Dyn
Leo_Dyn
OK, so I think I have a pretty good grip on inserting model attributes into custom title blocks. What I am wondering now, is if there is a way to insert an attribute manually into a drawing.
For instance, say I don't always want mass to show up in every drawing, but I do want to show it in one specific drawing. Is there a way I can just insert that into the drawing? Without changing the title block in my drawing template?
sutherland-
Facing the same here.
Interested in it as well. 👍🏻
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
ClintBrown3D
Hi @Leo_Dyn
You could set up an additional title block with the additional (or fewer) attributes.
Once set up, it's really simple to switch between them.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
g-andresen
I would just add the attribute.
(view in My Videos)
You can also place the attribute outside the title block, whereby the positioning at this stage is done by trial and error due to the lack of a drawing view.
günther
Leo_Dyn
@g-andresenOh. Does doing that NOT affect your original? Meaning any edits to your title block are ONLY in this drawing? If so, then yeah, that'll work perfectly fine!
Leo_Dyn
@ClintBrown3DAha, yeah that would work as well. Bit more work to setup, but likely pays off in the long run. Thanks!
g-andresen
Exactly
günther
