In an assembly with two blocks (example attached) I can rotate the second block by parameter, but after the rotation I still can rotate it freely by hand. When I change the rotation parameter again, the movement starts at the current position. Somehow the parametric rotation is relative, not absolute. All other dimensions are absolute, driven by the parameters. I would like to have the rotation absolute, in the 'as built' orientation, or with another reference, but I don't see how to accomplish that.
Using bodies or components made no difference.
Thanks in advance.
