Assembly question, timeline
Felipe.G
Felipe.G
Hi, I'm having trouble with an assembly, making modifications to it, I know I probably did something weird, i can share the file to the support (fusion 360) to figure what went wrong.
I have attached a simple screencast showing that when i try to edit the part, the part to which is referenced to, is not shown.
Thank you
Beyondforce
Hi @Felipe.G,
1. I can see, you didn't follow R.U.L.E #1 as you should have!
2. Have you tried to locate the sketch in the browser and open it from there?
3. Is it an imported component?
4. I can also see a Yellow (warning) work plane in the Time line - Not good!
4. It will be very helpful if you could share the file.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
O.Tan
Hmm, lemme guess. Did you move the component to better position it sometime in the assembly?
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Felipe.G
I think that may happened, I had to do the assy again, short in time for now, but that may have been the problem, i will check previous version to see if i can replicate the problem, thank you for the help
Felipe.G
Thank you all for the help, but will try later to replicate my mistake, I had to redo the assy again for mow, thanks again for the help
TrippyLighting
Your mistake is very easy to re-create. You are using a workflow that is suboptimal for your design.
You are creating sketches, which is why you have a sketch folder at the top level.
Then you crete bodies from these sketches, which is why you have bodies folder at the top level.
Then you create components from these bodies.
When you move a component to a location different from the original position it was created in, the body in that component and the sketch are not in the same position anymore.
Following the R.U.L.E #1 workflow will avoid this as sketches, features etc.  will be part of the components they belong to. When you move a component everything moves with it.
Felipe.G
Ok, Did it again on a copy of the file and found the problem I had the first time, I have attached a bit longer screencast of the problem.
So basically i got stuck back into trying to rebuilt the part because the sketch is not available.
