Assembly Joints
Assembly Joints
Message 1 of 8
Assembly Joints
Please help,
i want to joint one component through two supports. But "Joint" options only let me choose one location for each component. What should I do if I want to join one component through two supports into another component?
I had attached two screenshots with the two components.
Thanks a lot!
Replies (7)
Message 2 of 8
TrippyLighting
Use a revolute joint on one of the cylindrical extrusions and a cylindrical joint on the other. It might also work with 2 revolute joints.
in any case the above requires that the holes distance to be precisely the same on the two mated parts.
Message 3 of 8
jeff_strater
Two revolute joints will work, as long as your geometry is precisely aligned.  You will get a warning that you are creating two joints between the same components.  Just say "yes" to this warning.
Jeff Strater
Engineering Director
Message 4 of 8
i did it but still doesn't work.
Message 5 of 8
holes distance and mated parts are the same. I tried both options and still doesn't work. In order to fix the assemble more or less in the desire position I have to edit "Alignment"...
Message 6 of 8
TrippyLighting
can you share your model ?
Message 7 of 8
jeff_strater
Here is the workflow I used for a similar situation:
If this does not work for you, post your model, as @TrippyLighting says, and one of us will take a look
Jeff Strater
Message 8 of 8
it worked! Thanks
