Assembly in Fusion 360
Would like to know how to do assembly of 3 seperate part files , all of these are imported as parasolid
daniel_lyall
Start a new design and save and name it.
Then from the data panel right click on the part and select insert into current design when it's in position ground it by right clicking on it in the tree and select ground
Repeat for the next part and attach it to the first part useing a joint then inset the 3rd part and use a joint again to connect it where it goes.
Save the file after each part is inserted into the design.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
