Assembly Explodes when I edit a Joint.
SlawsonEngineering
SlawsonEngineering
See screencast below.  I'm not sure why the model explodes when I try to re-assemble a component with a joint.
jeff_strater
Editing a joint takes you back in the timeline to when that joint was created.  So, all components will be in the positions and states that they had at the time that the joint was created.  I suspect that this is all that is going on in this video.
Jeff
Jeff Strater
Engineering Director
SlawsonEngineering
Is there a way to "reset" this so I can move it from it's new position?
