assembly drawing suggestions/help
kwertmanX3F6N
kwertmanX3F6N
I am working on improving assembly drawings with student projects. We are building a battle bot and I made an attempt to make a drawing of a bot. My understanding of how assembly drawings work is every single part of the bot is a separate component. When I go to machine the parts I can turn off all the parts except the one that I would like to CAM out. As I was creating my assembly drawing I kept getting multiple components that were acting as one. This makes creating toolpaths for each individual part impossible. It also seemed as though making a copy of a component messed with the ability to individually select components. My main purpose in the drawing is for machining. The graphics are to prove the parts will work together once assembled. I will try to attach the file. Im not sure what file type to use for an assembly. The forum wont accept the STEP file I created. Any help would be greatly appreciated.
TrippyLighting
If you are teaching your students 3D CAD that maybe we can agree to use the proper terminology. Usually my stomachs starts revolting when someone starts referring to a model as a drawing 😉
Yes, all discrete parts in a design should be components.
To share a design you can either export it as a .f3d file or create a link to it directly from the design in the data panel.
TheCADWhisperer
...to expand on @TrippyLighting comments:
An assembly is a collection of components - the components might be individual parts or sub-assemblies of parts.
A part is, well, a part.   3D geometry.  In the CAD world we refer to modeling a part.
A drawing is 2D documentation of the Assembly or the Part - usually intended for printing on a sheet of paper.
If we are "drawing" a part or an assembly, then we are preparing the 2D documentation.
If we are working on 3D assembly or part - we are modeling in CAD.
You can attach your original Fusion file here by -
going to File>Export and save to your local drive
then Reply here and attach the *.f3d file here.
kwertmanX3F6N
I think this is a link to use. I'm not sure why but I cant save the f3d file locally to my computer or our network. Hopefully this link works. Considering I just taught board drawing for 13 years I guess I have developed bad habits. Having the resources to teach CAD is a game changer. Unfortunately this forum is my only source for Fusion training. I've had very good experiences from getting info from the CAM forum. If you can make some suggestions I would greatly appreciate it!
  http://a360.co/2lGK8nE
