Assembly component alignment problem
knndnnr
Message 1 of 9
knndnnr
Is anyone else having a problem like this? Have a look at the images. It is of a 2 room suite I am working on. The bedroom/bathroom is an imported component of the suite, and has the sub-components -mentioned below- of it's own.
Notice the change in position of the toilet, shower and bed. They have all sunk into the floor and the color of the toilet has changed to floor material.
Puzzling
Replies (8)
Message 2 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @knndnnr
Thank you for posting!
To better understand your issue, do you mind sharing your file ?
This would be helpful for us to find the right answer to your question. Smiley Happy
Many Thanks!
Message 3 of 9
knndnnr
Hi back,
Would be happy to. What do I do?
regards
Kenn
Message 4 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @knndnnr
You are able to use 2 ways.
1. Share you file by using the A360 : Here is how to
2. Export f3d file and attached on this post. (or send me ahreum.ryu@autodesk.com) : Here is how to
I look forward to your reply
Have a great day!!!
Many thanks
Message 5 of 9
knndnnr
Sharing through A360 sound best. Please send me your share link.
Message 6 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @knndnnr
Please invite me on your project .... Smiley Tongue  because we need to share your file...
1) In the Fusion  or
2).  https://myhub.autodesk360.com
my email address is " ahreum.ryu@autodesk.com"
I'm going to keep security your file.
Many thanks
Message 7 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @knndnnr
Thank you for inviting me on your project.
I've looked into your model. I couldn't reproduce the same situation with you. Smiley Sad
When I opened your joint, it was missing something... so I couldn't make the same.
Could you take a look at my way? if I missed something please let me know.
http://autode.sk/2b6slAk
I hided some parts in case. if you don't want to share this screen just let me know.
on your project, I just did save as the assembly file, you can see the "S4_V19_Ahreum" please refer to it.
I look forward to your reply.
Many thanks!
Message 8 of 9
knndnnr
Hi Ahreum,
I suspect that my problem in this model has never been seen before. None of
my many other projects have anything like this. I would suggest we drop the
issue unless you have nothing better to do with your time, as there is a
good chance on one else will ever experience anything similar.
It is quit weird though and I wondered if anyone else had come across it.
You should see what happens to the shower stall if I move it above the
floor in the sub-assembly. In the parent, the shower stall bodies are
spread all over the place!
If this project displays correctly on your system, that would suggest a
compatibility issue with my graphics driver, no?
regards
Kenn
Message 9 of 9
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @knndnnr
Thank you for replying Smiley Happy
I think we should discuss with meaning of joints
You created by using the top down skill (following the layout) so we couldn’t find “Joint” folder in your “BandB” assy. I suspect that you just use the Move function. In this case it looks fixed but if you move something it would be moved.
Please take a look at this.  http://autode.sk/2b3ueMb
There were 2 cases.
1. Assy without Joints --> Insert to the other Assy.
= bodies included will be moved seperately.
To solve, we use the "rigid group option or Asbuilt Joint"
2. Assy with Joints --> Insert to the other Assy.
= Bodies included will be moved together.
In conclusion, To solve this issue we can do 2 ways.
  1. added “Rigid Group” option
  2. Set the exactly location when you located part at first and then use “As built Joint”.
If you need more help, Please let me know Smiley Happy
Many thanks!
