Array of arcs sharing a concentric center, and radiating along one direction line
ea425019
Message 1 of 9
ea425019
I have an array that I am tasked to design, it bears similarity to what is shown in the attached file.
Two attachments are provided
1. MWPC Bottom only traces = provided by client, shows the pitch and direction expected. This is an array that will be sent to a electronics design software to make traces, said software cannot design traces
2. Presentation file... = What the screenshot below shows
Objective: I wish to get the radii matching as the arcs go outward, to share a concentric center.
Is there a method to do this?
Replies (8)
Message 2 of 9
jhackney1972
I am assuming you want a sketch in the Model Workspace.  I did not add sketch constraints to the arcs but you could.  I hope this is what you are looking for.
If this answers your question, please select the "Accept Solution" icon on my post, if you need further help please ask.  Model is attached.
John Hackney, Retired
Message 3 of 9
ea425019
Hi John,
Thanks for trying that.  What we need is a sketch in the model workspace, true, but the radii of each arc must be such that it comes out of the same center point.  The client's first attempt is shown here below.  These wire traces are intercepting a 1 axis mesh of wires, they get the traces very close around a rim, to a connector.  You can see that each curved line is parallel by virtue of it's being of different radii.   He had done this in SW, and I don't have experience with SW, and well, he is coming to me for help, wishing for a more algorithmic method, i.e. parameter tables, N+1 math, whatever it takes to not have to model each arc.
Message 4 of 9
jhackney1972
All my arcs have the same center and it duplicates your supplied picture.  It is unclear what you truly want.
Message 5 of 9
ea425019
Oh, what I see from the Patterned Arcs - JRH file is what is below. All the same radii and offset in position.  It's possible you sent me something 
different than what you describe?
Message 6 of 9
davebYYPCU
Fusion will need a script to do this, had a fiddle, took 2+ minutes to draw 200 circles.
similar to this (10 - 30cm at 1mm spacing)
        rds = 10
        while rds < 30:
            circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), rds)
            rds = rds + 0.1
Took almost as long to trim them back.
Might help....
Message 7 of 9
ea425019
That is neat, thank you! I did write a script as shown below, it fails to recognize 'circles' and gives me an error. I had preemptively made a parameter called "rds" but I will play with it some more and see.
Message 8 of 9
davebYYPCU
With no experience, I followed a tutorial from Learn Everything about design, (YouTube)
Drawing a sketch profile,
You will have to declare a few more variables, like which sketch and where do circles come from, Bit over my head, (or I would a sent my attempt you might know these things) but got it working,
He warned about default units in API being cm so double check the unit handling.
If you have experience, you can ask the 3 variables required, 1st and last radius, and step value, to make it useful.
Might help….
Message 9 of 9
etfrench
Try this code sample using offsets.  It shouldn't need any trimming.
ETFrench
