I shelled a body, and I'm trying to clean up and thicken some areas inside. I want sketch lines that coincident to the edges inside, so they became projected, which should be fine. However, when I attach a regular sketch line to it (with Coincident), I lose the ability to move the line or dimension it.
If I draw a line and dimension it, and then make it coincident to one of the purple lines, the dimension disappears.
I got my triangle sketch to function (for an extrude), by instead using the .12 dimension from the outside, but I shouldn't need that.
By they way in view settings is there a way to turn off visibility of projected lines?
