Arc not creating coincident automatically
In older versions of Fusion 360, when I created a centre point arc on a line to create a half circle, all three points would snap to the line and the coincident will automatically be created for all three points.
After an earlier update of the software, only the centre point and the first point would create the coincidents automatically but the last point will still need the coincident to be manually added. (A clear snap takes place but no coincident is created)
Perhaps there is a method or setting to make this happen when placing the arc on a straight line.
I only ask this as many of my designs demand lots of arcs in one sketch and it is very time consuming to go back to add coincidents manually.
The attached sketch show how the last point on the 4 arcs do not have the coincidents created.
This same design will have many of these features and while I often can mirror and pattern them, in some designs I need to create multiple ones.
TheCADWhisperer
I simply create circles and trim.
