Apply custom texture to model
janikows
janikows
I want to apply this texture to the roll and have to wrap around it realistically, and the side of roll shouldn't have that texture applied to it. What's the best way to accomplish this?
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
laughingcreek
right click on the body and select "texture map controls". then play around with these settings to get the best mapping to your object-
also, you can apply texture by face instead of to the entire object-
