Applied apperances are getting changed ... why??
aabhineshh
aabhineshh
I applied my choice of colours to the model I designed..... . but, once i save the model, the apperance seems to have changed a bit. This happens everytime when, I save the file. please help me solve this issue 😟😟 because, i need to render this model as fast as i can.fusion doubt 2.png
jeff_strater
you'll have to share the design to get an answer, I'm afraid.  Is is possible you have duplicate components or bodies in the same place, one colored, one not, and which one "wins" varies depending on subtle graphics changes?
Jeff Strater
Engineering Director
aabhineshh
Im sorry, that I haven't explained the problem clearly, in my first post. Actually, this took lot of time to understand.
I don't know how to share the design file but, I will explain what happened.... .
This how my model looks after adding all the appearance. I applied them face by face.....,it took a lot of time.
 1 .  My created model, and notice how I applied appearances to different faces.
2. here, I wanted to creat a new body. so, I started a sketch and extrude it.
3. it was by default in cut option but, then I changed it to 'new body'.
4. here, I have changed it to new body and click ok.
5. now is where the problem starts. when I move the large body down a bit, see all those       bodies have lost their appearances 😭😭😭.
Annotation 2021-07-07 234256.png6. now, no bodies have any appearence on them.
This may seem a bit, not a kind of problem thing. but, for me after applying those looks                                                      on my design [It took more than one hour to do appearance], and suddenly by, a small                                                        error all those work is gone..... I was literaly taken a back when this happened. "pretty                                                        sure it is a bug. 😁
        " sorry for lengthy explanation..... . I will attach the image files below"
jeff_strater
Thanks for the explanation.  Yes, this seems to be a bug.  However, try doing a Compute All - in my test this seems to bring the face colors back:
Jeff Strater
aabhineshh
