Appearance Library
Appearance Library
kellings
Advisor Advisor
Message 1 of 8
Appearance Library
kellings
How do I get the items in the appearance library that aren't on my computer to download? If I uncheck show downloadable materials, most of the items disappear. I can't seem to figure out how to trigger the download of the materials.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Replies (7)
Message 2 of 8
schneik-adsk
Do you have an update downloading? You would see "XX%" Downloading in the titlebar?
Typically you should see a little down arrow next to any appearance you don't have.
Kevin Schneider
Message 3 of 8
kellings
No updates pending. Attached is a full screen shot so you can see there are no pending updates. I've even pulled up the appearance library and walked away for an hour or two thinking it had to download the rest of the materials. I've been getting the updates. I don't remember seeing that any of them have failed. This is using OS X too. I haven't fired up Windows to see what I see there yet.
Kevin Ellingson
Message 4 of 8
schneik-adsk
I'll need to check in with the Rendering experts. Stay tuned.
Kevin Schneider
Message 5 of 8
jakefowler
Hi Kevin,
Thanks for reporting this, this does look strange - we'll look into this.
The one time I've seen something like this before happened because the list items didn't resize to the dialog window correctly, and the download button was just sitting 'out of bounds'. So one thing to try might be to resize/scroll the Appearances window and see if this makes a difference.
Many thanks,
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Message 6 of 8
hutchij
Are you cliking on the individual library items that you want to download? Each has a download button. There is no batch download.
John
Message 7 of 8
kellings
@jakefowler wrote:
Hi Kevin,
That was it. I just had to resize the dialog. I couldn't resize the dialog until I undocked it from the side. Now the arrows appear.
Thanks for the help guys.
Kevin Ellingson
Message 8 of 8
jakefowler
Great! Glad that worked.
Playing around a bit here I've just been able to reproduce this problem - I'm going to ask the development team to look into this and see if we can stop these buttons from getting hidden.
Many thanks again for highlighting this,
Jake
Jake Fowler
Fusion 360
