Please see component cam:1 sketch cam.
I am trying to edit the top left of the sketch. There is a blue line connected to an 45 constrained line, extended from the projected line.
I and enter a line and grab the ends or middle and move it around, but as soon as I connect to the constrained line i am unable to move anything about the blue line.
Why????
When I try to change the length dimension of the line it gives the error failed to solve, I can see no constraints added to the line other than the one coincident constraint.
Oh and I have rebooted fusion
Okay I have some green projected lines if a draw a line from a green point the line is constrained coincident when the line is created and the rest of the line remains free to move, but when I connect to the purple projection, the line is not automatically constrained to the point, and is free to move, but as soon as I make one end coincident to the purple geometry the line is not free to lengthen or rotate about the point?
The sketch has no warnings to review.
Okay so now I can add a line to the purple geometry, and it becomes coincident and can be moved, as is expected, and the dimensions are working again......
No idea what i did to "fix it" feels glitchy.
