Any way to enlarge these fillets?
eerier_bleach0f
eerier_bleach0f
Figured it out. Had to make a negative of the model and enlargen the fillets on the negative and then use the COMBINE tool. BUT had to split the negative in half first. One side would work no issue but the other literally identical side would throw errors for no reason.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
g-andresen
In this public forum it is also customary to make hints and example files available to every user and not to store them on the "private" level.
günther
If you have problems with people, you should not express your concerns in this forum.
Comments like the one in the following sentence are unacceptable
… If your name isn't Seth Madore, include your email address,…
eerier_bleach0f
What person do you think I have a problem with? I have certainly not expressed my concerns about anyone in this post. What comment is unnaceptable?
I solved my own issue, this post was edited. That's why there's no info.
eerier_bleach0f
Oh. No... I'm not sharing files publicly. I don't need Seth's email, I already have it.
