Another V-Groove Question
mitchdryden
mitchdryden
Only new to Fusion 360, so still learning, be gentle🙈
I'm looking to place a 90 degree bend in a 2mm thick piece of aluminium, I was playing around in the program(could have been the sheet metal part, cant remember) but I could have sworn I saw a 'v groove' tab or button? Am I dreaming? As I cant seem to get back to it or find it again.
I'd like to be able to use a bit like below, as I will be bending said piece myself by hand and want to minimise the bend radius.
https://www.endmill.com.au/panel-folding-v-bit/
I've done a lot of searching in the forum and on the net with no concrete answer.
Regards
Mitch
etfrench
You can do that easily in the Manufacturing workspace. First place a sketch line where you want the bend.  As you can see in the screencast, the line needs to extend past the edges of the workpiece to allow for lead-ins and outs.
ETFrench
mitchdryden
@etfrench  Thanks for taking the time to reply  appreciate the help, havent quite got it yet but getting close.
Cheers
Mitch
