Hello!
One of my first post here. I always manage to find answer myself but this time I tried everything and cannot find a solution... I prefer not to use the form/mesh mode as I found it (with my experience) less precise...
So the problem I have is that the loft always make a small hollow on the center line. I kind of understand in a way why he is doing that and at the same time I'm like "why don't you follow my rail?"!!!
This hollow is really obvious when I manufacture the piece on my CNC...
You can see on the picture, I want the part highlighted in orange to be "flat on the center line" as my upper bout rail is.
I think Fusion struggle here as I go from one curve to a really different one with 2 rails constrain. It is less worst if I loft from the upper bout curve to the center point and use the center curve as rail.
I join also an export of my Fusion 360 file if someone want to look at it, All the strating sketch are there as also all my test (with mesh and other surface).
Do you have any idea?
