annoying new error: draft angle resets after new face is selected
stiller.design
Message 1 of 8
stiller.design
Hi folks,
not sure why but since the last update the draft angle resets after new face is selected, which if you do injection molded parts is freaking annoying. does updates actually get tested before being published?
sorry for the rant , but those introduces bugs are such a pain. I want stability more than new features to be honest
@jeff_strater
Replies (7)
Message 2 of 8
stiller.design
anyone with the same issue?
Message 3 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 4 of 8
wmhazzard
At the top of the dialog box, you need to change from Fusion default to last used or set up a favorite.
Message 5 of 8
laughingcreek
@jeff_strater - is this the bug related to extensions?
Message 6 of 8
jeff_strater
 I think it could be.  But, from what I can see, this bug should have been fixed in the Mar 29 update.  @stiller.design - can you check whether there is a pending Fusion update?
Jeff Strater
Engineering Director
Message 7 of 8
stiller.design
I am running the latest version of Fusion 360 (2.0.12670)
this only happens if the Product Design extension is activated. If not activated it will act normal
Message 8 of 8
Gus-Collier
2025 still have this issue with Product Design Extension. Maybe it's defaulting to an unset plastic rule?
