Animation
Animation
papae93
Animation
papae93
While doing an exploded view animation, one component was not added to time line. Is there a way to add it manually? The component is in the browser. The rest of animation seems fine. Thanks.
innovatenate
Autodesk Support
Autodesk Support
If you right click on the comnponent in the browser and select Manual explode, does this give you what you're looking for?
Nathan Chandler
Principal Specialist
papae93
Thanks for your reply. Not sure if this would have done the trick. but while experimenting before I saw your post, I relocated the componant in the view and it was added to the time line.
