Animation Show/hide bugs
anton.persson
anton.persson
Hello
I have an issue with the show/hide function in the animation workspace.
There is actually more than one issue so I will list them below
1. When I activate show component and try to do so gradually it just pops up instantly no matter how I set up graduality. And this is only on some components and not all. (0:07)
2. If I perform the same action as above some components are doing it gradually different so, for example, it will show inside of my roller blind before it will show outside  (0:19 - 0:24)
3. When I move my camera in certain situations it jumps and doest move as smoothly as it should have. (0:35)
These glitches are very annoying for me right and I hope someone can give me some help or tips.
PS. Is there any other good program that I can use for 3D animation with the help of STEP files?
Ajay_Kumar_Reddy
I got your problem
3. I didn't observe any glitch at 00.35. the animation was quite good,. Because it is avi your PC might have struggled to load the media.
2. The sequence that you enable and disable things matters. You might have enabled the body before or after you actually want it to be
1. You can edit it in camtasia adding fade effect to it. Even you can do it fusion I think.
I'll try if you can send me the project you are working with or you can add me to the project if you don't mind
(ak47bhoom@gmail.com)There is no glitch effect in hereThere is no glitch effect in here
